Geometry.Intersect error
At the moment I get a error from the node Geometry.Intersect. The error says at follow: Curve join produced more than one WIRE in polycurve. The script worked perfect on another polycurves but now a tried it on some other polycurves and iI get this error. I have seen that this error is some what common but couldn’t find the solution in other threads. I added the script and the two CAD files I use to extract the polycurves from.
ERROR polycurves.dwg (397.0 KB)
SUCCES polycurves.dwg (459.2 KB)
DYNAMO script.dyn (99.1 KB)
Someone has a solution for this I still can’t figure it out.
Hi Hugo,
I’ve looked into the issue and i feel like there’s something wrong with the polycurve. I think it has a tiny gap in it, but I’m not entirely sure.
I tried fixing it in your script:
I’ve added the PolyCurve.Curves node and set the listlevels of the geometry intersect node.
Hope this helps!
-Daan
Polycurve error fixed.dyn (374.8 KB)
Thanks man that did the trick! I think indeed the problem is in the curve but thanks again for the answer!
