hello what was the solution? i have same issue, the rooms of another building appear on top of another building on the side overlapped, crazy…
Never skip the Primer
Its all there
if that would be so simple I would have resolved already and i would not be here writing stupid post comment, i saw this but one of the nodes does not work in my revit 2023 Aligning linked geometry using Dynamo for Revit! - YouTube @GavinNicholls @Marcel_Rijsmus
I tried this following the video and still does not work correctly:
# IronPython 2.7 - Dynamo for Revit (no required inputs)
# OUT:
# [0] RevitLinkInstance[]
# [1] Types[]
# [2] CoordinateSystem[] (host-space, from each link's total transform)
# [3] elements[i][j] -> elements from linked doc for instance i, category j
# [4] dsGeom[i][j] -> DS geometry in link-space
# [5] dsGeomHost[i][j] -> DS geometry transformed to host-space
import clr, System
# --- guard IN so default-arg crashes never happen if node has no inputs
try:
IN
except:
IN = [None]
# Revit Services / API
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import (
FilteredElementCollector, RevitLinkInstance, ElementCategoryFilter,
BuiltInCategory, Category, ElementId, Options, ViewDetailLevel,
GeometryInstance, Solid, Mesh, SpatialElement, SpatialElementGeometryCalculator
# Dynamo geometry
clr.AddReference("ProtoGeometry")
from Autodesk.DesignScript.Geometry import CoordinateSystem, Point, Vector, Geometry
# Dynamo Revit wrappers/extensions
# ----------------- helpers -----------------
def _unwrap(x):
try:
return UnwrapElement(x)
except:
return x
def _as_list(x):
return x if isinstance(x, list) else [x]
def _unique_by_eid(elems):
seen = set(); out = []
for e in elems:
try: k = e.Id.IntegerValue
except: k = id(e)
if k not in seen:
seen.add(k); out.append(e)
return out
def _to_bic_list(maybe_cats):
"""Accept None | Category | ElementId | BuiltInCategory | int | 'Rooms' | 'OST_Rooms' | list of any -> list[BuiltInCategory]."""
if not maybe_cats:
return [BuiltInCategory.OST_Rooms]
cats = _as_list(maybe_cats)
bics = []
for c in cats:
c = _unwrap(c)
# BuiltInCategory?
if str(type(c)).endswith("BuiltInCategory"):
bics.append(c); continue
# Category -> BIC
if isinstance(c, Category):
try:
bics.append(System.Enum.ToObject(BuiltInCategory, c.Id.IntegerValue)); continue
except: pass
# ElementId -> BIC
if isinstance(c, ElementId):
try:
bics.append(System.Enum.ToObject(BuiltInCategory, c.IntegerValue)); continue
except: pass
# int -> BIC
if isinstance(c, int):
try:
bics.append(System.Enum.ToObject(BuiltInCategory, c)); continue
except: pass
# string
if isinstance(c, basestring):
s = c.strip()
if s == "Rooms":
bics.append(BuiltInCategory.OST_Rooms); continue
try:
bics.append(getattr(BuiltInCategory, s)); continue
except: pass
if not bics:
bics = [BuiltInCategory.OST_Rooms]
return bics
# Geometry extraction from DB.Element -> list[DB.GeometryObject]
_opts = Options()
_opts.IncludeNonVisibleObjects = False
_opts.ComputeReferences = False
_opts.DetailLevel = ViewDetailLevel.Fine
# cache SpatialElementGeometryCalculator per document
_calc_cache = {}
def _get_room_solid(elem, rdoc):
try:
calc = _calc_cache.get(rdoc, None)
if calc is None:
calc = SpatialElementGeometryCalculator(rdoc)
_calc_cache[rdoc] = calc
res = calc.CalculateSpatialElementGeometry(elem)
return res.GetGeometry() # DB.Solid
except:
return None
def _expand_gobj(go):
out = []
if isinstance(go, Solid):
# keep non-empty solids
try:
if go.Volume > 1e-9:
out.append(go)
# even "empty" solids may have faces
faces = list(go.Faces)
if len(faces) > 0: out.append(go)
except:
out.append(go)
elif isinstance(go, Mesh):
out.append(go)
elif isinstance(go, GeometryInstance):
ig = go.GetInstanceGeometry()
if ig:
for sub in ig:
out.extend(_expand_gobj(sub))
# curves/symbolic lines often not useful for volume; skip
pass
return out
def _db_element_to_db_geom(elem, rdoc):
geos = []
try:
g = elem.get_Geometry(_opts)
if g:
for go in g:
geos.extend(_expand_gobj(go))
except:
pass
# Rooms: robust solid via SpatialElementGeometryCalculator
if isinstance(elem, SpatialElement) and not geos:
rs = _get_room_solid(elem, rdoc)
if rs is not None:
geos.append(rs)
return geos
def _dbgeom_to_ds(dbgeom_list):
ds = []
for go in dbgeom_list:
try:
ds.append(go.ToProtoType())
except:
# some geometry types may fail; skip safely
pass
return ds
# ----------------- main -----------------
# 1) link instances
instances = list(FilteredElementCollector(doc).OfClass(RevitLinkInstance))
instances = _unique_by_eid(instances)
# 2) types
types = []
for inst in instances:
try:
types.append(inst.Document.GetElement(inst.GetTypeId()))
except:
types.append(None)
# 3) coordinate systems from each instance's total transform (host-space)
coord_systems = []
t = inst.GetTotalTransform()
o = t.Origin; bx, by, bz = t.BasisX, t.BasisY, t.BasisZ
p = Point.ByCoordinates(o.X, o.Y, o.Z)
vx = Vector.ByCoordinates(bx.X, bx.Y, bx.Z)
vy = Vector.ByCoordinates(by.X, by.Y, by.Z)
vz = Vector.ByCoordinates(bz.X, bz.Y, bz.Z)
coord_systems.append(CoordinateSystem.ByOriginVectors(p, vx, vy, vz))
# category selection (default Rooms) — can wire IN[0] with Categories/BICs if desired
requested_bics = _to_bic_list(IN[0])
# 4) elements per instance per category
elements = [] # elements[i][j]
dsGeom = [] # dsGeom[i][j] in link-space
dsGeomHost = [] # dsGeomHost[i][j] transformed to host-space
CS_identity = CoordinateSystem.ByOrigin(0, 0, 0)
for idx, inst in enumerate(instances):
try:
ldoc = inst.GetLinkDocument()
except:
ldoc = None
inst_elems_per_cat = []
inst_ds_per_cat = []
inst_ds_host_per_cat = []
if ldoc is None:
# Unloaded link: fill empties per requested category
for _ in requested_bics:
inst_elems_per_cat.append([])
inst_ds_per_cat.append([])
inst_ds_host_per_cat.append([])
for bic in requested_bics:
try:
coll = FilteredElementCollector(ldoc).WhereElementIsNotElementType().WherePasses(ElementCategoryFilter(bic))
cat_elems = list(coll.ToElements())
except:
cat_elems = []
inst_elems_per_cat.append(cat_elems)
# Convert to DS geometry (flatten by element)
link_ds_geo_flat = []
for e in cat_elems:
db_geo = _db_element_to_db_geom(e, ldoc)
link_ds_geo_flat.extend(_dbgeom_to_ds(db_geo))
inst_ds_per_cat.append(link_ds_geo_flat)
# Transform DS geometry to host using the instance CS
host_ds_geo_flat = []
cs_target = coord_systems[idx] if idx < len(coord_systems) else CS_identity
for g in link_ds_geo_flat:
try:
host_ds_geo_flat.append(Geometry.Transform(g, CS_identity, cs_target))
except:
# If any geometry fails to transform, skip it
pass
inst_ds_host_per_cat.append(host_ds_geo_flat)
elements.append(inst_elems_per_cat)
dsGeom.append(inst_ds_per_cat)
dsGeomHost.append(inst_ds_host_per_cat)
OUT = instances, types, coord_systems, elements, dsGeom, dsGeomHost
Hi! Did you see this post: Geometry from linked file, by shared coordinates, appears on the wrong place in Dynamo - #12 by danail.momchilov
You could also send your graph here, along with a set of sample files and I could fix it for you
