Dynamo reports room boundary at wrong location
Hi everyone, does any
one know why dynamo reported my room boundary @ wrong Y location ? and How can i fix this ?
Are those rooms from a linked file? If so you need to translate the geometry after. Spring nodes has nodes that obtain the transforms from links.
Hi, like John mentioned, if you are taking the geometry from liked file, you might need to translate it first. There are many nodes doing just that in Spring nodes, Archilab, Bimorph, etc. I struggled with the same issue before, you could check this topic:
Yes these are geo. from linked file. Thank you both.
Hi Danail, follow your other thread and its solution i used BIMorphNode, Dynamo still returned my room location from linked file shifted. Do you have any other advises for me ? Thanks
I replied in the topic, check my last post there :slight_smile:
