Genius Loci - Get Shared Parameter brings null
I tried it already and it works. For that one I have to save family in project to somewhere and then load it back to project. Last week it worked and now weird…
you may can try from different machine.
Okay, is there anything I can do let me know…
Thank you very much for your efforts! I tried in Revit 2019.2 and it works…
The question is now: why is it like that?
Deniz,
First, you need to load the shared parameters text file.
After, the Get Shared Parameter node can read the content of the file.
If you only want the parameters of your family, there is the FamilyDocument Parameters node.
Hello Alban!
Nice to hear from you!
I had already loaded the .txt file to family.
grafik
I would like to get groups and parameters from SharedParameterFile. I think I found something via Clockwork:
I’m glad you found a solution.
It is working fine on my computer with Revit 2020.2 :
I think my Revit is somehow broken. I will get it repaired or install 2021 :slight_smile: I will let you know about that!
Merci :slight_smile:
