Generation design
I want to ask why my output values cannot gene[quote=“kenken9884, post:1, topic:106079, full:true”]
I want to ask why my output values cannot generate data, thank you all
[/quote]
1131125形狀系數測試.dyn (36.5 KB)
*rate data, thank you all
Hi. I checked the file, and you set the output to the watch node. I changed the output to Math.sum node, and the result came out.
Translated by moderator. See below the line for original post.
Thank you I will try again
Original post below.
謝謝你 我再試試
