Generating different Identity data for the same family in Revit
Hey guys!
I just recently started learning about Dynamo and I have a bugging issue in Revit which I continue to do manually but I want to automatize it.
I need to name all of these foundation piles in Revit to have a name that starts with “P” and then continuous to numbers from 1 to n, I choose it to be in Identity Data - Comment section (as shown in photo).
Can you suggest any shortcut for this via Dynamo?
Thanks in advance!
This is how I would do it:
Numerated Family Type Parameter by ZYX Position.dyn (56.9 KB)
p.s. I suggest you swap values between mark and comments, because using comments as mark could be confusing…
Agreed it’s not straightforward to sort by multiple criteria
Alternative using python
Code
OUT = sorted(enumerate(IN[0]), key=lambda pt: (round(pt[1].X, 3), round(pt[1].Y, 3)))
If you just need the indices
OUT = [
    i[0]
    for i in sorted(
Nice!
I used that lambda function:
Now I’m just curious how can we round the Z value even more? For example, I would like Z_rounded(128)=100, or Z_rounded(178)=200…
round(n, -2) will round to the nearest 100
great, ty
Wow, thanks a lot guys!
