Hi guys.
Did you know, is it possible to get full list of all most installed packages?
Thx
Havee a good working day!
Hi guys.
yes those are on my list
Most downloaded = most installed I’d say, which can sort packages in the search tab. Votes are also a good metric to use generally.
A little web scraping
the process is a bit long…a lots of packages…
import sys
import System
from System.IO import *
from System.Net import *
import json
min_downloaded = IN[0]
most_installed_packages = []
request = WebRequest.Create ("https://dynamopackages.com/packages/")
with request.GetResponse() as response:
with response.GetResponseStream() as stream:
with StreamReader(stream) as reader:
html = reader.ReadToEnd()
json_string = html.encode("utf-8")
stud_obj = json.loads(json_string)
contents = stud_obj.get("content")
for content_dict in contents:
nbr_download = content_dict.get("downloads")
if nbr_download is not None and nbr_download > min_downloaded:
most_installed_packages.append([content_dict.get("name"), nbr_download])
most_installed_packages.sort(key = lambda x : x[1], reverse = True)
datatranspose = [i for i in zip(*most_installed_packages)]
OUT = datatranspose
