It will be awesome, if Dynamo Primer Guys continue the Zero-Touch exercise
Exercise 1 - Edge Detection and show complete workflow by converting the edge on image to real dynamo curve geometry
24 - ZeroTouchImage.dyn (12.3 KB)
exercise 2 shows how to do just that ?
http://dynamoprimer.com/en/10_Packages/10-5_Zero-Touch.html
I don’t think so Andrew
I Explain, Exercise 2 show how to create simple geometry base on dynamo geometry(PointByCoordinates).
What I want is to convert the Edges in that image to curve or surface
Why not use Illustrator or some online image vectorizer like http://www.autotracer.org/?
As for a dynamo method maybe something like this:
curves from image.dyn (26.5 KB)
Thank you Viktor
I want that in Dynamo Geometry, because I want the Area of each Pattern.
Or Autodesk Raster Design ?
