From Dynamo to Revit
I am using StructuralFraming.BeamByCurve component to upload my geometry into Revit. Most of my geometry got in but I am having trouble with two curves. The component gives me the warning below:
Did anyone get this error before? Do you know how to fix it?
Thank you !
It’s probably your curves. You need to use a simple curve with only a single radius.
Thank you. I changed the curve definition and it worked.
