Hi all,
I am looking for a way to extract the surface area of specific faces of my conceptual mass model in FormIt. I decided to assign a certain material to those faces I’m interested in. For example: I would like to know the (summed) surface area of the three faces with red brickwork in the attached screenshot (nr 1).
Using the Dynamo node ‘Surface.FilterByOrientation’ I am able to extract the area of surfaces with a specific orientation (horizontal up/down and vertical, see screenshot nr 2). However, I did not find an equivalent node with which I can filter by surface material? Does this exist?
Or does anyone of you know an alternative method?
I already tried the same with mass objects in Revit, but here too, I did not succeed in extracting the painted surfaces of my masses, neither using Material takeoff schedules nor using Dynamo code…
Thanks for your reply!
PS. I did read the post https://forums.autodesk.com/t5/formit-forum/can-formit-provide-areas-for-different-materials/m-p/988…, but I am looking for a more automated method to export the area measurements outside of the FormIt Materials panel.
