Following a Dynamo Tutorial
Hi, so I am trying to follow the Light Pole Placement from the Dynamo website Light Pole Placement but some nodes are no longer existing, I opened the dynamo file made available to follow and for the nodes that I have mentioned there is a warning that the nodes cannot be resolved. I am wondering if there are any replacement nodes I can use and if anyone knows them? I have also attached a screenshot
Thank you in advance
Which version of Dynamo are you using? This appears to be one of the samples for Dynamo for Civil3D, but you appear to be in Dynamo Sandbox or Dynamo for Revit. As a result all of the nodes which interact with the Civil 3D application are not resolving.
I think you are right! I am using Dynamo for Revit, does that mean that I can’t use the same application process ?
Would it be possible to use the nodes if I downloaded the Civil 3D add on, do you know ?
That means you can use Revit functionality, but not Civil 3D functionality.
It is possible to use those nodes if you install Civil 3D and launch Dynamo from it instead of from Revit.
I have the model in Revit and would like to know if it is possible using different nodes to get the same outcome as the link above but in revit ?
Sure - but you’ll need to do some legwork. As an example I do not believe that Revit has a concept of feature lines, so defining those will have to happen separately.
