CivilConnection nodes not working
Hi everyone,
I’m trying to use the Dynamo CivilConnection package, but for some reason the nodes are not working:
I’m using Revit 2019.2, Civil 3D 2019 and Dynamo 2.0.3. I installed the package CivilConnection2019 following the Linear Structutes Workflow Guide, but even the first node to make the connection with Civil 3D (CivilApplication.CivilApplication) does not work.
Any idea what the reason could be?
Thanks in advance!
FYI @Paolo_Emilio_Serra1
@dair can you tell us what the warning from the CivilApplication.CivilApplication node is?
@dair can you try 4.0.1? Apologies I made a mistake when compiling 4.0.0 that prevented CivilApplication to work.
Thanks, @Paolo_Emilio_Serra1 and @jacob.small !
I downloaded the 4.0.1 version and now it is working :slight_smile:
@Paolo_Emilio_Serra1, @jacob.small,
First time working with CivilConnection and having similar issues as described above. I run Autodesk Revit 2020.2.2, Civil 3D 2020.4 and Dynamo 2.2.0.5885. I have installed the latest version of CivilConnection2020 (5.0.0).
Am I missing something? Both Revit and Civil 3D is open. Please help?
Thanks!
Not sure what the issues was, did a good old restart and all is working now…
Cheers
Hi everyone,
I’ve the same issue with Revit 2021.1.1 and Civil 3D 2021. I installed the package CivilConnection2020 version 5.0.4.
Hi. The same for my side. I was using my Dynamo script succesfully with Revit and Civil 2020, and now when I switched to 2021 (CivilConnection version 5.0.4). The very first node doesn’t work:
What can I do about it?
Btw. I am working on a Virtual Machine (Microsoft Azure), if that could be important. I checked also version 4.0.4. Doesn’t work also - the same error with CivilApplication.CivilApplication - Warning: CivilApplication…ctor operation failed.
Object reference not set to an instance of an object…
with civil3D2020.6.3,Revit2020,Dynamo revit 2.1,Civilconnection 2020-5.05,
this is the issues :
anyone can help me ,thanks a lot !
Paolo is it very active on the forum anymore. Best to post a new issue to the GitHub, as this feels like an installation thing. 2020 is a year outside of the support window so I have uninstalled that and I don’t have hdd space to reinstall to try and troubleshoot.
I meet the same problem with revit2020,civil3D2020,Dynamo2.3
