Floors by Rooms
I made two simple graphs for creating floors and ceilings by using room geometry.
However, sometimes it works, but sometimes it doesn’t.
I’m uploading Revit test file and the graphs. In this model, I created three levels that have the same layout. Even though the layouts are the same, the script fails on level 3.
Open dynamo and try it out. For example, select all rooms by “Name”, value “Bathroom”, and Level 1. The script works just fine. Then, select all rooms by “Name”, value “Bathroom”, and Level 3. The script fails.
I have tried using different nodes for creating floors, but the problem is still there. I’m starting to think that the room boundaries are causing this. Maybe Dynamo sometimes fails to create a continuous loop or something like that…
How can this be solved?
Thanks.
Finishes by Rooms 1. Floors.dyn (107.6 KB)
Finishes by Rooms 2. Ceilings.dyn (107.0 KB)
PolyCurve.ByGroupedCurves solved the issue. One of the best nodes out there.
Finishes by Rooms 1. Floors.dyn (98.0 KB)
Finishes by Rooms 2. Ceilings.dyn (98.1 KB)
