FloorPlan.ByRoom is unable to create multiple views at a time
I am trying to create multiple floor plan views for multiple rooms to be used in sheets. I used the node FloorPlan.ByRoom custom node from the archi-lab.net 2019.2.26 package.
The node is only creating one view at a time. On setting it to automatic or periodic runs i have to switch between true and false to create the next view. After creation of each view the node give an error shown below:
After the node has created all the views by switching between true and false its gives the correct output.
So is there any way that the views are created in one run as I ultimately need to create views for a much larger building with many room??
Well thanks to archi-lab for such a great lab as even in current situation a lot of my time as compared to manually creating it.
Try setting lacing to longest or use list levels.
Yes changing the lacing to longest worked. Thanks a lot.
