Can anyone tell me why this node produces this error the first time i run it ? It creates the plans but outputs an error message which causes problems as I want to feed the output plan views into further nodes.
Weirdly, if i then change the offset straight away and hit run again it then works (it doesn’t matter what the initial value is set to , it doesn’t run right first time
Yeah the trouble is i want the graph to then put those views onto a sheet along with some elevations so doing that causes the other nodes downstream to mess up
