Floor.SlabShapeByPoints
Hi Guys, I wonder if someone can help me.
I am trying to use Floor.SlabShapeByPoints to create ramps in Revit. However, it seems some of the points are getting stuck with original z value 0 from the flat slab.
Can you share your rvt file and dyn file so we can reproduce the issue?
Hey Jacob
Here is the Rhino file where slab began, I can’t upload the gh script, but I am turning the surface boundary into arc and straight lines then export 3 points per arc and 2 points per line. Dynamo script attached reads points and creates slab. Thanks for taking a look!
Cheers
ChrisCreateFloorSlabByPoints.dyn (56.6 KB)
FloorSlabByPoints.rvt (1.1 MB)
FloorSlabs.3dm (1.3 MB)
