Hi all,
Trying to flatten a nested list while keeping the structure of the list in python, how do I do it properly?
In essence, what I am trying to achieve in python script is what I am getting in List.Flatten.
see graph below for details:
Hi @Thomas_Corrie thank you for your answer, just edited the question to clarify what I am seeking. Basically, I got the answer in list.flatten node, however, I can’t mangae to get the same result from python node. So the answer I am after should be in python.
But again thanks for taking the time to solve it
I see, I thought you wanted the other way around
@Thomas_Corrie thanks
My Python skills are limited but how about this? There’s almost certainly a more Pythonic way to do it
# Enable Python support and load DesignScript library
list1 = IN[0]
outlist = []
for x in list1:
outlist.append([])
for y in x:
if type(y) is list:
for z in y:
outlist[-1].append(z)
outlist[-1].append(y)
# Place your code below this line
# OUT = flattenlist(list2)
OUT = outlist
Thank you
@Thomas_Corrie fantastic answer!
Your skills are quite advanced in python
@saeedy3 you’re welcome, and thank you! That solution works for your particular level of nesting but if you had some deeper lists then it would be better to have a recursive function to allow for more flexibility. But if your data is in that consistent structure then this should work well.
