Hi All,
How could i reduce this to one script?
- repeat list 5 times.
- flatten list.
- find string and output result.
Hi All,
Hi @Kulkul , thanks for the reply. Perhaps someone else can help?
Here is what I’ve done for a list.
I get stuck on the nested list, how can i flatten this?
Any help would be great. Cheers
Hi @Lknapton
I don’t fully understand what you are trying to achieve, but to flatten a nested list,
you can just iterate through it twice > iterate over sublists,and iterate through each item in sublist
If you are dealing with an unknown long nesting depth, you would need recursion, but that seem to be the case.
Here an example of how you can get to all the nested items
Here is an example of flattening, but also excluding/including based on a condition, similar to what you have done:
Another way:
lst = [["a", "b", "c", "d", "e"]] * 5
lst2 = [i for i in [j for i in lst for j in i] if "b" in i]
OUT = lst2
func = lambda item : [j for i in lst for j in i]
lst3 = [i for i in func(lst) if "b" in i]
OUT = lst3
import itertools
lst2 = list(itertools.chain(*lst))
lst3 = [item for item in lst2 if "b" in item]
OUT = lst3
The fact that you can doesn’t mean you should.
I personally like to avoid list comprehension for nested operations.
It’s easy to break into a loop first, then use comprehension on the nested level.
I find it this VERY hard to read.
Who says that?..
@Organon I think nested list comprehensions are tricky to read, especially for beginners.
I didn’t intend to sound rude or dismiss your reply as a valid solution
I actually thought @Lknapton had pasted an answer from somewhere else (your white thumbnail image tricked me)
so I wanted to encourage him to try a less complex solution
Ok, it’s just a misunderstanding.
Regards
Thanks for all the help
