So, by using a number of different threads across multiple forums I managed to create a script that places a detail line at the base of a Revit wall. The lines represents a Fire Rating. It works great for floor plans, but I also want to apply the same process in a section view.
So far, you have to first created line patters in Revit, and then assign these patters to Line Styles (Each represents a Fire Rating… 0.5 HR, 1 HR, and so on). An instance parameter for Fire Rating is then assigned to walls (there is already a Type Parameter for this, but you don’t want to create a new type for each Fire Rating). Each of these represent a different fire rating.
The Script then checks for the value of this parameter where it places a fire rated line style on the corresponding wall on the level you pick.
But i also want to show it on section. How can this be done?
Fire Rated Walls.dyn (47.3 KB)
