Finding the 'element' from dimension in c#
Im trying to convert one of my Custom node made in python to C#.
Im trying to get the 'element 'which is dimensioned from the dimension element.
if the tag is single tag then I can get the element directly , but if it is multi tag then I have to get the dimension element attached to and then get the rebar element attached to the dimension element.
duptags%20Py
duptags%20c%23
				Document doc = Document;
		var activeview = doc.ActiveView.Id;
		StringBuilder results = new StringBuilder();
		#region Collectors
		FilteredElementCollector tagscollector = new FilteredElementCollector(doc,activeview);
		FilteredElementCollector rebarcollector = new FilteredElementCollector(doc,activeview);
		ICollection<Element> tagsinview  = tagscollector.OfCategory(BuiltInCategory.OST_RebarTags).ToElements();
		ICollection<Element> rebarsinview  = tagscollector.OfCategory(BuiltInCategory.OST_Rebar).ToElements();
		#endregion
		#region Lists initiaitons
		List<ElementId>taggedrebarid = new List<ElementId>();
		List<ElementId>allrebarid = new List<ElementId>();
		List<IndependentTag>alltags = new List<IndependentTag>();
		List<IndependentTag>duptags = new List<IndependentTag>();
		List<Dimension>dupdims = new List<Dimension>();
		List<ElementId>duprebarid = new List<ElementId>();
		List<Element>dupbars = new List<Element>();
		List<ElementId>uniquerebarid = new List<ElementId>();
		#endregion
		foreach ( IndependentTag t in tagsinview)
			alltags.Add(t);
		#region Getting all tagged element IDs
		foreach (IndependentTag t in tagsinview)
			Element e = t.GetTaggedLocalElement();
			if (e is Dimension)
				Dimension dim1 = (Dimension)e;
				ReferenceArray ref1 = dim1.References;
				HashSet<ElementId> refIds = new HashSet<ElementId>();
	            foreach (Reference r in ref1)
               		refIds.Add(r.ElementId);
            	taggedrebarid.AddRange(refIds.ToList());
        //Add the rebars to a list
       		else
       			taggedrebarid.Add(t.GetTaggedLocalElement().Id);
		#endregion
		#region Getting all rebars ids
		foreach ( Rebar r in rebarsinview)
			allrebarid.Add(r.Id);
		#endregion
		#region getting rebars tha tare tagged twice
		for ( var g = 0 ; g < taggedrebarid.Count(); g++)
			if(uniquerebarid.Contains(taggedrebarid[g]))
			   duprebarid.Add(taggedrebarid[g]);
			else
				uniquerebarid.Add(taggedrebarid[g]);
		foreach(ElementId rebid in duprebarid)
			dupbars.Add(doc.GetElement(rebid));
		#endregion
		#region text output taskdialog
		/// taskdialog window reuslts
		var resultswindow = new TaskDialog("No of tags")
			MainContent =taggedrebarid.Count().ToString() ,
				CommonButtons = TaskDialogCommonButtons.Yes
		resultswindow.Show();
		#endregion
You can do something like this:
    public static List<ElementId> TaggedRebarsInView(UIDocument uidoc)
        Document doc = uidoc.Document;
        //get rebar tags
        ICollection<Element> fec1 = new FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_RebarTags).ToElements();
        List<ElementId> taggedRebarIds = new List<ElementId>();
        foreach (IndependentTag tag1 in fec1)
            Element e = tag1.GetTaggedLocalElement();
            //Multirebar tags are attached to a dimension, and wee need to find what rebar the dimension is referencing.
            if (e is Dimension)
                taggedRebarIds.AddRange(refIds.ToList());
            else { taggedRebarIds.Add(tag1.GetTaggedLocalElement().Id); }
        return taggedRebarIds;
