Selecting Parent Element(Multi Rebar Annotation) from individual Tag Id
ok
I took your script and recoded in a different way, I guess is simplified, I was not understanding everything in the previous one.
clr.AddReference('RevitAPI')
coll = FilteredElementCollector(doc,doc.ActiveView.Id)
tagsinview = coll.OfCategory(BuiltInCategory.OST_RebarTags).ToElements()
duptags = []
unique = []
for t in tagsinview:
	id = t.TaggedLocalElementId
	if id in unique:
		duptags.append(t)
		unique.append(id)
OUT = duptags
I hope this is what you were looking for
Il use this code…Its clearer…However your using’ single tag’ on a single rebar i use multi rebar tag on groups of rebars …my problem is when you run the code …and get the element , tags and isolate …the tags will not be seen in the isolated view only the elments wil be shown.
