I am attempting to write a script that will select all objects that, in a particular view, are not currently dimensioned.
Here is how to select modeled elements that have a dimension string attached to them in entire project, you better select only one view.
#Einar Raknes 2017
# Import List ( ICollection(ElementId) = List[ElementId]() )
clr.AddReference('System')
# Import Revit API
clr.AddReference('RevitAPI')
# Input
dimensions = UnwrapElement(IN[0])
ids = set()
for dim in dimensions:
for ref in dim.References:
ids.add(ref.ElementId)
OUT = [doc.GetElement(id) for id in ids]
