Associating Tags with Tagged Element
So when i try t oassociate the tag with the elemnt i get wrong results since the number of tags is not equal to the number of rebars
I want to assicate the particular rebar with the tags so i can select the correct tagin view
Add the “listofRepeatedItem” after the “tag” node, and make the number “Rebars” output up.
  • There is quite a topic in the forum about your comment.
  • Dynamo screenshot share with us. We’d better see your code.
i solved it using different method
I’m glad you solved your method. Could you share the method to guide friends who have the same problem as the solution you are using.
Durmus
https://www.linkedin.com/pulse/checking-duplicate-tags-revit-using-dynamo-python-kumar-igbc-ap/?published=t
