hello, I’m using an isovist node and what I want to do basically is if the isovist point is analyzing in the room that has windows, it tells you the area value. However, if you are in a room that has no window, it doesn’t tell you anything.
my isovist is based a point that I created on revit environment.
I’m trying to
- find / filter all the rooms with / without rooms
- If the point/isovist is in the room with window, it tells the area value
- if not, it just says an error statement.
thank you very much!
