Hi all,
I’m trying to make a dynamo script that will cross-reference an excel sheet with the families loaded within a project.
I’m having trouble with the List contains giving the correct answer / matching the two list meaning I can’t get an accurate bool mask.
Please help!
FYI I’ am a little trial and error with dynamo so I could definitely be going about this all the wrong way
load_families_excel.dyn (52.7 KB)
@sparkyduke , hi
be aware when you filter elements by mask… they have the same count!
i think you have to use transpose … to fit your input.
KR
Andreas
That might pose an issue. What im hoping to do is check my projects loaded families against a large list, so they will never be the same count. How can I check a small list against every line in a longer list to return a True value when they match. Is that something that can be done?
Hello @sparkyduke …not sure but how about a way with "all indicies ?
Hey @sovitek .
Look like List.AllIndices need to be a number I,m working with Strings
Though I seem to be having a bit of success using List Filter by String Nodes
The Issue now is that I have 16 elements on the list, which is the other strings returning false under each list.
Is there a node/way to compress that and have the 4 returns only [False,True,False,True]
00 load_families_excel.dyn (50.7 KB)
here is a potential lead
Cordially
christian.stan
Hello instead of string from object just get the name of the family and compare
For this one try to change lacing then add List.AnyTrue node.
Hey @truevis, you nailed it cheers.
Setting list.AnyTrue with longest lacing worked a treat.
