Filtering Levels and apply correct workset
I have some levels that have been assigned to an incorrect workset and i am trying to use Dynamo to correct this slight problem.
I found this post [Filter All Elements of Family Type selection by parameter] which seems to address my problem, bus so far i have been having a hard time getting the Levels to be set to the correct workset.
Here is my DYN (Revit 2015 and Dynamo 1.1) -
@Tom_Kunsman Can you upload your dyn file again.It seems it is not properly uploaded.
@Tom_Kunsman Shouldn’t parameter name be “Workset” instead of “REW Architectural”?
I only uploaded a capture of it, but I will try again.
assign levels.dyn (5.2 KB)
Hmm, even if I switch that I still get Levels which I know are on an incorrect workset but do not show up in my watch node.
Tom,
The workset parameter that your extracting is an ID number not the name.
@Tom_Kunsman Workset storage type is Element id. You can’t feed names to it.
Looks like @Monkey_Puppet and i replied at the same time both solutions are exact match :smile: :smile:
@Kulkul great minds think alike :wink:
