eylulc
September 5, 2024, 12:31pm
1
Hello everyone,
I am someone who is trying to learn Dynamo lately.
I have a minor task (it is not minor for me)
I am trying to assign every elements does not include “grid” word in certain parameter to the certain workset.
Like: Every ceiling element does not include the word “grid” in their XXX parameter should go into the AAA workset kind of a stuff.
But no matter how I try, I could not figure out the problem.
You can find the screenshots attached. Any help will be reallyyyy appreciated.
Edit: image updated
What does the error message say?
I think you just need to remove the List Map node, and feed the list directly to the Element.Setparam node
eylulc
September 5, 2024, 12:36pm
3
Warning: Element.SetParameterByName expects argument type(s) (Revit.Elements.Element, string, var), but was called with (Function, string, null).
This is the error message
eylulc
September 5, 2024, 12:37pm
5
Thanks. I tried but still giving the same error
I think your not supplying a valid workset, can you show what the workset.id node is outputting?
eylulc
September 5, 2024, 12:42pm
7
This is what I am trying to do. I got the workset from name. And connected that to the ID because element.setparameter only works with Id (I guess)
But clearly I did something wrong
You did not change my original suggestion
eylulc
September 5, 2024, 12:44pm
9
Oh no I did. I just undo it. Here is the new version
You need to feed the list of elements into the list.Filterbyboolmask instead of the parameter values.
eylulc
September 5, 2024, 12:52pm
11
Yes, it worked. But the problem is, I was trying to make the elements which does not contain some certain parameter. That is why, I added not node. However, now it converted the element who has the word “grid” to the new workset.
But this was helpful anyway, thank you
You can remove the Not node then.
The fitlerbyboolmask gives you the true filter and false filter (in, out)
So if you want only the elements that tested false, you take the ‘out’ output, if you want the elements that tested true, you can use the ‘in’ output.
eylulc
September 5, 2024, 1:00pm
13
Ohhhhh now it worked completely.
Really appreciated
Don’t forget to mark solutions so others can more efficiently learn from the conversation!
