Change workset by selection
Please help, if you can.
I have downloaded a code that I can select as many elements and object as a I wish and change their levels in one go. the code works perfectly.
Now, I wanna do the same for “Workset”
here is the screenshot for the existing code. and the code can be downloaded if you like to have a closer look.
The reason I do this, because my designing team has created lots of elements and objects on lots of different work sets and levels.
I have managed to sort out the leveling and have deleted all the unwanted levels. and now I need to do the same for the work set.
Please note, that I am not a wiz on Dynamo, in fact, I am less than novice!
Thank you in advance.
This could help,
the german word “Bearbeitungsbereich” means “Workset”:
“Worksets” and “Workset.ID” from “Archilab”
Great, which version of Dyn are you using? I have dyn Revit: 1.3.4.6666 and dyn: 2.0.3.0
I used 2.0.3.8811
I keep getting this error! :frowning:
I tried downloading
But I use Revit 2018.3
I use this:
archilab
Revit
Unfortunately I can not get those nods! :frowning:
keeps telling me I am using newer version of Dyn!
and I can not downgrade!
update
Install Dynamo for Revit 2.0.3, not 0.6.3.
