Filtering Hosts by intersection
Hi Guys I am trying to create voids by Inserting Families ( Generic Void Families ) into the floors to be a void family that cuts the floors according to the Column ( Sheet Pile Location ) .
The thing is when I select more than one floor the script considers only one floor and the elements that they are intersecting with the same floor. It doesn’t filter the hosts by intersection .
The result is like this
can I Filter the hosts with the columns that they are intersecting , if this approach would work how can it be achieved ?
How can I create the voids according in different floors if the columns are intersecting . I would appreciate any help
Here’s a way of ordering your intersects to get a list of floors aligned to the columns which intersect them… You can then use your family node at level 2…
Hope that helps,
Mark
Hi Mark.
Much appreciated thanks a lot
