Hey Guys, I´ve got some surfaces and the Points in the middle of that surfaces. I create a vector through each Point and compare them two zweo separate vectors.
I get obviusly correct results in the lists. And when I further use the node List.FilterByBoolMask I also get some potentielly correct results. After that I filter those lists with the “==”-node and List.FilterByBoolMask again. Now on the one Hand I get correkt surfaces with one vector. On the other Hand I get wrong results in the “==”-node.
The Question is about the third Picture.
Does anyone know why I can´t filter the correct surfaces? If I sort that list or drop some items, I´ll always get the wrong surfaces. Somehow after filtering the Elements seem not to be connected to the IDs.
The rvt and dyn are attached.Filtering a list by VectorIsParallel.dyn (111.6 KB) Filtering a list by VectorIsParallel.rvt (3.5 MB)
