it’s my first post here in the forum, so if I did the post wrong my apologies.
I developed a dynamo that indentifies if a solid intersects the other,
first I select all the families and then all the other families that I want to check if they intersects, however I’m facing troubles when there is more than 1 solid, it needs to associate the solids that intersects the other and join both, I don’t know how to filter just the two solids that are intersecting in the list
Looking at the setup you have now you would want to change the inputs around of the Geometry.DoesIntersect node, since you want to get 8 results per Solid.
As option A: I would suggest flattening both your Element.Geometry nodes output, to keep the nodes later on more manageable.
As option B: Then I would suggest replacing your List.Flatten node with a List.NormalizeDepth node with a depth of 2.
PS: I don’t know which list levels/ lacing you might need from the top of my head, if you still aren’t able to figure it out, please upload some sample files (Dynamo/ Host if applicable).
