I cannot for the life of me figure out how to filter with multiple parameters. All I want is to remove the items in list one from list two. I know one of you are going to make this incredably easy and make me feel like an idiot but I simply can not figure it out.
It looks like its working because the lacing is set to logiest but its really only running Shaft Openings a bunch of times and the first three once.
I actually figured out that if you change the lacing on contains to “Cross Product” it drastically minimizes the graph.
I also noticed that Mark Thorley’s Zebra package has a similar node that does this, but has much more under the hood. Maybe suggest the revision to him?
I like to filter elements in a similar matter and have a node that does just that in spring nodes, called “Filter.ByCategoryName”. You can also use partial category names.
Also the built-in “All Elements In Active View” node was performing very poorly for me on a larger project, so I suggest you try the “Collector.ElementsInView” node instead.
That is a much simpler approach. I have noticed the pore performance of all elements in view as well. I was looking for one with a view input but could not seem to find it. Thank you for that as well.
