List Filtering By Multiple Strings
I’m trying to clean up my graph a bit and am curious if there is a better approach to filtering than just daisy chaining List.FilterByString nodes. For one or two inputs it isn’t terrible but when I have a big list the chances of missing something or lacing incorrectly goes up quite a bit. Purpose of the graph is to help clean up families by deleting sub-categories that are excessive and don’t belong, leaving the ones I want to keep.
I just tried Vikram’s solution in this thread and John’s solution in this thread with out much luck. odds are it is something dumb but I’m stumped…
DeleteSubCategories_Graph
DeleteSubCategories_Forum.dyn (66.0 KB)
I used walls in this example, but the idea is there. (Also using OOTB nodes primarily)
EDIT- The blue section should have said “Note the cross product lacing”
Hi @Chad_Clary
Have you tried List @ Level Functionality http://dynamobim.org/introducing-listlevel-working-with-lists-made-easier/
Filtering the list per @john_pierson 's suggestion (BoolMask) works to separate the list but when I connect it to the Tool.Eraser nothing is actually processed and erased (it returns a null). Any thoughts on why?
The upside is I figured out List@Level thanks to John & @Kulkul :smiley:
edit: forgot the updated graph
You need to put the subcategories into the list input on the “List.FilterByBoolMask” node. Right now it is outputting strings
That fixed it. Thanks! :beer:
