Filter list by a parameter information
Dears,
I’m trying to to do the following one:
I’ve got four parameter which it belongs to “walls” category. (Revit blue group). Then, I’ve tried to make a list with this parameters to get a xls file at the end.
The headache comes from… From all the data what I got, I only want what in the parameter “FCC_Zona” has the text “ASCENSOR_2”. You could watch it such as red highlighted in the last node “Watch”. The filter must respect the information of each “List”, I mean, “386 List” must keep “0 ASCENSOR_2”, “1 MF1” “2 ASCENSOR 2 DEFINICIÓN GEOMÉTR”, "3 ", and so, with all which on line “0” has “ASCENSOR_2”.
How could I develope this filter?
Thanks in advance
Did you try using List.OffRepeatedItems node?
You could try filter using a bool mask with List.FirstItem. See attached picture.
filterbyfirst
Looks like @kennyb6 and i replied at the same time :slight_smile: both solutions are the same tho :smile:
Thanks both of you. Solved
Please mark @kennyb6 post as solved.
