Hi team,
I think I am almost there. Can you have a look? In my case I want to add the text “GAP” to the set below value only to the dimension is 16, I hope you can have a look
cheers
Hi team,
cheers
Hi Kai, looks interesitng ill give it a go, however which is the node before categories (to he left) i just can see the cable.
Cheers
you can ignore that one, that was me looking at the “All elements of category” rather then going the category and view route
Hi Kai,
This is the script updated as per the one you shared. However, now it is not filtering the dimension just to apply to the 16 one but is applying to all. Do you have any suggestions?
Looks like it’s a continuous dimension, maybe have a look here Dimensions SetBelow for specific dimension in a continuous string - #2 by john_pierson
Cheers Kai
Thanks mate, this way is so easy
thanks for the help
