Hey guys.
I am really fresh at dynamo.
I need to write something above or below my dimensions which goes through all over the facade.
After a while, i found some ready to use dynamo script and use it. Now it works but i need to filter dimensions for example 3/4’’ is joint but if its bigger then 3/4’’ i want to write Panel Width.
Or maybe if its possible, first i choose only dimensions which length value is equal 3/4’’ than for my pannel which is bigger than 3/4’’
So im really look forward for your answers. Thanks!
Have you tried using this?
Thank you Revit_Noob but i have no idea how to connect nodes that you advise me.
TextAddForDimensions.dyn (6.5 KB)
here is the script that im already use. could you show me how its connecting?
@barisbagis how are you i try the same idea you need and i get this result
my issues is this script didn’t work on continuous dimension i must separate the dimension to work
You could try this Python script to see if it works Please note this has been written for the metric system, so if you’re in the US it will be a little different.
dimensions = UnwrapElement(IN[0])
text = IN[1]
value = IN[2]
results = []
for dim in dimensions:
numOfSegs = dim.NumberOfSegments
if numOfSegs > 0:
for num in range(numOfSegs):
seg = dim.Segments.Item[num]
if seg.Value * 304.8 > value:
dim.Segments[num].Above = str(text)
results.append(dim)
if dim.Value * 304.8 > value:
dim.Above = str(text)
results.append(dim)
OUT = results
It will set the chosen text above the dimension - but only if the dimension, or dimension segment, is greater than your chosen value
thanks @solamour for your advice but i need to apply the text for a chosen value not to a value greater than another value
@solamour kindly can i ask you about the package where i can find (View.current)
View.Current and Collector.ElementsInViewByCategory both come from the Designtech package
You can achieve both with out-of-the-box nodes … it just takes a bit more!
Side note - Code has been amended to now only do text on top of dimension values that match:
text = IN[1]
value = IN[2]
results = []
if numOfSegs > 0:
if round(seg.Value * 304.8) == value:
results.append(dim)
if round(dim.Value * 304.8) == value:
results.append(dim)
OUT = results
