anyone knows how could I get subregions boundaries from a toposurface … to create filled regions with?
Thanks in advance
Thanks in advance
Select face node.
Surface.PerimeterCurves node.
Geometry.PullOntoPlane.
Filled Region (clockwork I think).
Thanks for the answer @jacob.small. However, the Select face node doesn’t work with subregions. I’ll keep searching…If you have another idea, i’ll hear it!
Got a basic example Revit file?
Thanks a lot @jbo !! , I can start working with it!!.
In the other hand, I was exploring another way.
I select the subregion, and with a little code, I can get the boundaries, but they still Autodesk.Revit.DB Elements. Do you Know how to transform in revit element to create polycurves with? It will be easier this way, I think.
It really works!
Thanks!
SAG_v2_créer_zoneremplie_à_partir_de_sousrégion.dyn (21.0 KB)
Of course! (Sorry for my notes, they are in French. Anyway, it’s all clear in the post)
Thanks again @jbo !
(Next step, try to select multiple subregions…)
