Hi Community,
I was trying to create filled region from cad link but im getting an error.heres the progress.
Thank you.
Just luckily solved it myself
if anyone has the same issue here’s my solution
Python
# Assign curves to groups according to whether they are connected via shared start points and end points. Group numbers are not important.
# Colin McCrone, 2015-09-28
import math
# Determine whether two points are equal
def PointsEqual(pt1, pt2):
tolerance = 0.00001
if (math.fabs(pt1.X - pt2.X) < tolerance and
math.fabs(pt1.Y - pt2.Y) < tolerance and
math.fabs(pt1.Z - pt2.Z) < tolerance):
return True
return False
# Get input
crvs = IN[0]
# List the group to which each curve belongs
crvGroup = [-1 for x in range(len(crvs))]
crvGroup[0] = 0
maxGroupNum = 1
# Find start and end points for each curve
starts = []
ends = []
for crv in crvs:
starts.append(Curve.PointAtParameter(crv,0))
ends.append(crv.PointAtParameter(1))
# Find connected groups of curves
for i in range(len(crvs)):
# Add i to its own group it not already part of a group
if (crvGroup[i] == -1):
crvGroup[i] = i
# Find connections
for j in range(len(crvs)):
if (i != j and
(PointsEqual(starts[i], starts[j]) or
PointsEqual(starts[i], ends[j]) or
PointsEqual(ends[i], starts[j]) or
PointsEqual(ends[i], ends[j]))):
# Add j to i group
if (crvGroup[j] == -1):
crvGroup[j] = crvGroup[i]
# Add j group to i group
elif (crvGroup[i] != crvGroup[j]):
oldNum = crvGroup[j]
for k in range(len(crvs)):
if (crvGroup[k] == oldNum):
crvGroup[k] = crvGroup[i]
# Output the (arbitrary) group numbers
OUT = crvGroup
