Group.Curves - Not connecting curves get grouped
Hello Dynamo Friends :smiley:
I want to make polylines out of the sketch lines of a slab.
I`m getting the error for the long black line on index 8.
So i tried to delete all other lines and test if that helps, and that actually did work:
Then i saw the problem are these 4 lines:
Because they get grouped with the long line as you can see in the first picture.
But they should not because they are not connected:
So the problem is the group.curves node, so what are my alternatives?
Happy about any help, thanks!
Kind Regards :slight_smile:
Ok, sorry, i got it, there is a tolerance of 0.1 in the code.
i changed it to 0.001 and it works now :slight_smile:
#Copyright(c) 2015, Konrad Sobon
# @arch_laboratory, http://archi-lab.net
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
inputCurves = IN[0]
#join/group curves function
def groupCurves(Line_List):
	ignore_distance = 0.1 # Assume points this close or closer to each other are touching
	Grouped_Lines = []
	Queue = set()
	while Line_List:
		Shape = []
		Queue.add(Line_List.pop()) # Move a line from the Line_List to our queue
		while Queue:
			Current_Line = Queue.pop()
			Shape.append(Current_Line)
			for Potential_Match in Line_List:
				Points = (Potential_Match.StartPoint, Potential_Match.EndPoint)
				for P1 in Points:
					for P2 in (Current_Line.StartPoint, Current_Line.EndPoint):
						distance = P1.DistanceTo(P2)
						if distance <= ignore_distance:
							Queue.add(Potential_Match)
			Line_List = [item for item in Line_List if item not in Queue]
		Grouped_Lines.append(Shape)
	return Grouped_Lines
OUT = groupCurves(inputCurves)
