Group PolyCurves by Distance, but only according to their start- and endpoints
Hello everyone,
I am working on a script which gets (2D) Civil3D Blocks into Dynamo to turn them into 3D Civil3D Objects. The problem which i am facing right now is that PolyCurves which intersect with other PolyCurves which are already Closed, see image below:
This wouldnt be a problem if i could just Close the Blue Polycurve, except i cant do that because i have other Objects in my file which look like this: (As you can see the Surface is wrong)
I think the solution here lies with the fact that in the first screenshot the lines are not connecting at their start- or endpoints but they are at the second image. But i dont know how to group Curves only by their start- and endpoints
I hope i was clear enough, and that someone knows a good way to approach this :slight_smile:
Regards,
Daan
Files:
Complex Road Marking Script V4 04-12-2020.dyn (33.5 KB)
RoadmarkingDWG.dwg (892.9 KB)
Try a group curves node from Archi-lab. It may not load in C3D but last I checked it was a custom node which means you can copy / paste the contents D4R to add the code to your graph, save the graph, and open it in C3D to get the good stuff.
Okay thanks for the tip, i’ll try that!
Ps: what does D4R mean?
Hi Jacob,
I tried to do the thing that you said but i am getting this error:
I don’t know how to solve/ approach this because i don’t know a lot about Python.
The Script:
#Copyright(c) 2015, Konrad Sobon
# @arch_laboratory, http://archi-lab.net
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
inputCurves = IN[0]
#join/grou    p curves function
    def groupCurves(Line_List):
    	ignore_distance = 0.01 # Assume points this close or closer to each other are touching
    	Grouped_Lines = []
    	Queue = set()
    	while Line_List:
    		Shape = []
    		Queue.add(Line_List.pop()) # Move a line from the Line_List to our queue
    		while Queue:
    			Current_Line = Queue.pop()
    			Shape.append(Current_Line)
    			for Potential_Match in Line_List:
    				Points = (Potential_Match.StartPoint, Potential_Match.EndPoint)
    				for P1 in Points:
    					for P2 in (Current_Line.StartPoint, Current_Line.EndPoint):
    						distance = P1.DistanceTo(P2)
    						if distance <= ignore_distance:
    							Queue.add(Potential_Match)
    			Line_List = [item for item in Line_List if item not in Queue]
    		Grouped_Lines.append(Shape)
    	return Grouped_Lines
    OUT = groupCurves(inputCurves)
I Think the error has to do with the fact that i am feeding nested lists into this Python script.
But i dont know how to change this script to also accept nested lists
Wrap it in a new custom node perhaps? How much do you need this to scale?
Hi @jacob.small,
Yeah i did that and now it works as expected!
Thanks for the help!!
