FeatureLine Add Elevation Points
Hello everyone,
I have no knowledge about python or any language but i want to try a simple script which goal is to add Elevation points to a Feature Line with a python script:
IN [0] = FL
IN [1] = Points
OUT = FL_edit
My sources are:
29 - Dynamo and Civil 3D’s API. Dynamo office hours
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
FeatL = IN[0]
pts = IN[1]
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Databaseas db:
with db.TransactionManager.StartTransaction()as t:
for fl in FeatL:
id = FeatL.InternalObjectId
FL = t.GetObjectId(id, OpenMode.ForWrite)
FL_edit = FL.InsertElevationPoints(pts)
t.Commit()
pass
OUT = FL_edit
This error shows up:
TypeError : No method matches given arguments for OnExit: (<class ‘Autodesk.AutoCAD.ApplicationServices.DocumentLock’>, <class ‘type’>, <class ‘TypeError’>, <class ‘traceback’>) [’ File “”, line 41, in \n’]
But I have no clue what I am doing (wrong)
Pay attention to the distance between
new and old points
manually
If they are too close together
gives an error
Thanks for your fast reply.
Im testing with a single FL and only 2 points.
Hi, @JaLo
Here are a few tips:
  • Be careful with methods that do not exist, such as ‘GetObjectId’. Check with the API documentation.
  • Be careful with the type of object passed as parameters in .Net methods.
  • The structure of your input lists must be consistent with your code (use zip if necessary).
code for CPython3
import sys
import System
dataEnteringNode = IN
import traceback
def toList(x):
    if isinstance(x, (list, dict)) or \
            (hasattr(x, "GetType") and x.GetType().GetInterface("ICollection") is not None):
        return x
    else : return [x]
lst_FeatL = toList(IN[0])
lst_pts = toList(IN[1])
out = []
acLckDoc  = adoc.LockDocument()
db = adoc.Database
t = db.TransactionManager.StartTransaction()
# Place your code below
try:
    for pts, FeatL in zip(lst_pts, lst_FeatL):
        array = System.Array[Point3d]([Point3d(p.X, p.Y, p.Z) for p in pts])
        locations = Point3dCollection(array)
        FL = t.GetObject(id, OpenMode.ForWrite)
        FL.InsertElevationPoints(locations)
        out.append(locations)
except Exception as ex:
    OUT = traceback.format_exc()
    OUT = out
    t.Commit()
finally:
    t.Dispose()
    db.Dispose()
    acLckDoc.Dispose()
A variant for the new PythonNet3 engine. (works with IronPython3 too)
import sys
import System
import traceback
def toList(x):
        return x
    else : return [x]
out = []
class CManager:
    a custom context manager for Disposable Object
    def __init__(self, obj):
        self.obj = obj
    def __enter__(self):
        return self.obj
    def __exit__(self, exc_type, exc_value, exc_tb):
        self.obj.Dispose()
        if exc_type:
            error = f"{exc_value} at line {exc_tb.tb_lineno}"
            raise ValueError(error)
        return self
    with CManager(adoc.Database) as db:
        print(db)
        with CManager(db.TransactionManager.StartTransaction()) as t:
            t.Commit()
OUT = out
Thank you very much!!
I actually do not know how to use the API info as elements are called in C#, VBA and so, and I find quite a few examples for Revit but no for Civil3D. Any video or written source is also welcome as Im looking forward to learn.
(Thanks again)
