FamilyInstance Origin Reference
Does anyone know any alternative package for this Genius Loci node? or a working code in revit 2025?
You can use OOTB to get the location and there is still the Genius Loci Element Reference node in R2025
Hi @rajeshjamariya16 try set the node to cpython 3, guess it will work then
clr.AddReference('RevitAPI')
import System
from Autodesk.Revit.DB import ElementId
def unwrap_and_flatten(obj):
    if hasattr(obj, "__iter__") and not isinstance(obj, Element):
        flat = []
        for sub in obj:
            flat.extend(unwrap_and_flatten(sub))
        return flat
        return [UnwrapElement(obj)]
# Get a clean flat Python list of unwrapped Revit elements
items = unwrap_and_flatten(IN[0])
location_points = []
ref_array = ReferenceArray()
for item in items:
    if item is None:
        ref_array.Append(None)
        location_points.append(None)
        continue
    # Use the global doc
    current_doc = doc
    if isinstance(item, FamilyInstance):
        # Build stable representation for the face of the family instance
        stable_ref_str = "{0}:0:INSTANCE:{1}:1:SURFACE".format(
            item.UniqueId,
            item.Symbol.UniqueId
        ref = Reference.ParseFromStableRepresentation(current_doc, stable_ref_str)
        ref_array.Append(ref)
        loc = item.Location
        if isinstance(loc, LocationPoint):
            location_points.append(loc.Point.ToPoint())  # Dynamo Point
        elif isinstance(loc, LocationCurve):
            # optionally take start or midpoint
            curve = loc.Curve
            location_points.append(curve.Evaluate(0.5, True).ToPoint())
if isinstance(IN[0], list) or hasattr(IN[0], "__iter__"):
    OUT = ref_array, location_points
    OUT = ref_array[0] if ref_array.Size > 0 else None, location_points[0] if location_points else None
Managed to create an alternative code in the process!
