Hi All,
I am having a problem in Revit 2019.
I have created a script to get the coordinates of given family instances in revit. This script is working fine in revit 2017, but in 2019 I am stuck at node “FamilyInstance.Location”.
I am getting a list of nulls.
Snapshot is attached:
Any help is appreciated.
Thanks in advance
Have you tried Element.GetLocation? I think that is the name of the node. It should be OOTB.
I tried this node…still getting the same error…![:slightly_frowning_face: :slightly_frowning_face:](https://emoji.discourse-cdn.com/twitter/slightly_frowning_face.png?v=9)
if you are using 2019.2 you need to update to dynamo 1.3.4 or 2.0.2.
what versions are you using?
Hi Michael,
Thanks a lot, it really solved my problem.
I was using 1.3.3, now switched to 1.3.4
may I know the cause for that?
Hi @shahed.attar -the version of the geometry library that Revit 2019.2 shipped was updated and Dynamo had to update to support it.
