I am not that experienced with dynamo, but I thought that I would give it a go as I needed a way of copying standard family parameters to COBie export parameters. I found this: http://autodesk.typepad.com/bimtoolbox/2015/10/parameter-mapping-in-revit-with-dynamo.html - as it only swapped out instance parameters, I swapped out some nodes (using archi-lab Get Type Parameter and Rythms SetParameterByName(TypeorInstance) nodes) to allow it to swap out Instance or Type parameters.
All going well until I want to copy out integer values for example; copying the value of Rough Height to COBie.TYPE.NominalHeight.
Looking at the output I can see that number values are not being picked up after going through the Get Type Parameter to Number node, however numbers, within instance parameters, are picked up through the Element.GetParameterValueByName node.
After thinking about this and getting no where, I wondered if anyone had resolved a similar problem. I think that the problem is related to the Python script in the Get Type Paramter to number node - I can not quiet work out how to turn the value into a string (the Python script seems to have integer to string already defined). The other problem that I can see is where I am trying to add a number value into a text value.
Any help would be gratefully received.
