Family parameter - type to instance
Hello forum
I am trying to change a family parameter from a type to an instance. I have found a few posts on this, but nothing recently with the node I am using - Clockwork FamilyParameter.MakeInstance.
I cannot get this to work, and the family.parameter I feed in always gets success=false.
Could anyone help me? Am I feeding in the wrong data? Here is a screengrab, and attached the family and .dyn.
Thank you very much for any help.
Tim
FAMILY PARAMETER MAKE INSTANCE.dyn (24.0 KB)
GLASS SINGLE.rfa (584 KB)
Hi @TimGreatrex not entirely sure but think orchid likes orchid nodes…
An alternate option here may work provided you are directly in the .rfa file
Cheers KS
You could have easily done that on DiRoots if that feature isn’t part of the subscription yet. not sure.
Hello @TimGreatrex here is another way if you are in a project and or in family…know its from instance to type, but openmep have a node for type to instance as well
Hi Kai
This is great, thank you so much! Really appreciated.
I will give this a go now.
Cheers
Tim
Thanks for this. I will check out this feature of DiRoots. Thanks!
Hi Sovitek
Thanks so much for this. I will give this a go too, it would be amazing to be able to perform this within the project on multiple families.
Thank you again!
Tim
Great…yes its possible as well, i like genius loci for that when in project document
Here is a way if in project
Hi Sovitek
This is wonderful! I cannot thank you enough for this. I will replicate this today and let you know how I get on. Thank you so much again.
Kind regards
Tim
