Changing type parameter of a loaded family without instance in poject
I have multiple loaded families in a project and I want to fill in one of their type parameters…
So lets make an example of two families:
  1. “Opening standard”
  2. “Recess standard”
both are structural connections and they share the same type parameter “xxx” and I want to fill “yyy” in that parameter for both families… the thing is I want to do this while setting up the project so there are no instances of these two families in the project yet so you cant select it using dynamo as an element because the element doesnt exist in 3D…
I cant seem to find a node which would take family type and let me change its parameter…
is this even possible? if so what node do I need to use?
Hi @juraj.valko7Q28C clockwork have some nodes there probably can help…
Also possible with OOTB nodes…
