@Sevag @ZoeM Ok then, use Solid.ByLoft node and not Surface.ByLoft node, run the script within a Conceptual Mass, select the imported instance and partially explode it, select the desired face and subdivide it:
Edit: Good luck with your homework
Yes Elie…more a question in a revit forum…btw think almost could be automated…but think this task its faster to do manuelly…just my thought…
No doubt @sovitek , their script stops at the geometry import, hence the helping hand, that’s all.
hehe so true
Hola amigos!!
@Sevag I do not know if I have understood well what you need or if you have already found a solution, a few weeks ago I saw a video of @GavinNicholls in his channel Aussi BIM Guru, very similar to what you are trying to do I leave the link maybe it will help you!!
