Hello. I would need to identify the cause of the following error. In Visual Studio, I created a library of one component in C# that I am uploading to Dynamo. Uploading the library and its functionality works perfectly on several computers. However, on some computers, the .dll library cannot be uploaded. When attempting to upload the library, an error message appears - “Failed to load library”. To verify that the error is not in the code or references, I cleaned up the code to just the minimum without using external references. The same error still occurs. I can’t identify what is different on the computers where uploading doesn’t work. Same versions of Revit 2022, same hotfixes, absolutely the same versions of Dynamo, same versions of operating systems…
Related topics
Topic | Replies | Views | Activity | |
Revit 2020 - Dynamo 2.3 - Genius Loci Package Failed to Load Library | 3 | 1834 | April 10, 2023 | |
Problem when deploying a package with versions later than 2020 | 5 | 178 | February 1, 2023 | |
Generative Design Revit Dynamo Load Error | 9 | 4086 | May 26, 2021 | |
Failed to load library | 0 | 683 | September 25, 2017 | |
Not show *dll library | 2 | 1481 | December 5, 2016 |
