Following with the theme of tunnels, I have been working and modifying in my scrip.
but I do not know how to continue, I wanted to do an extrusion and then a cast.
If someone knows how I can complete it I leave the archives, if I can get it I will publish the files.
As well as if there is another way to do it, I would appreciate it.
thanks to everyone.
PUNTOS_2.xlsx (9.9 KB)
TUNNEL_MOD__.dyn (83.0 KB)
Inter_Outer Tunnel Profile.rfa (420 KB)
try this,
start a new adptive family, run the script, select all profiles and the line and click create form.
i hope it works.
Marcel
Hello Marcel:
I already tried and this is the result, it should be continuous as one.
that’s why I wanted to extrude through the line and then a drain or squeeze the section already with the emptying.
also something happens to me that the section is turning and takes a kind of cant.
That’s how you need to organize your family’s.
Hello Durmus:
I will try at home since at work I have the 2019 version
Thank you
Hello durmus
I have only changed the excel file and this is the result
Will you try that?
Adap.Comp.Tunnel.dyn (78.5 KB)
Hello
I have looked at the section and it is 8 meters mine is 5 meters I will try to create an adatative and load it in the script.
Can you share your files?
Yes of course, without any problem.
In the tunnel section I’ve gone crazy setting up control points.
I pass the excel with the points and the dwg section.
Thank youPUNTOS.xlsx (9.6 KB) Seccion_tipo-.dwg (34.4 KB) BETONGTUNNEL2.rfa (416 KB)
Please review the Family file and try to make a copy. Because the code already works. The important thing is to produce the Family.
1.rfa (832 KB) 3D.rfa (1.4 MB) Adap.Comp.Tunnel.dyn (92.8 KB)
