First of all thank you all for helping so many people selflessly. I set up a script in the examples of the forums. that an imported excel file calculate points and curves. I import the type family I order with vectors, but I do not extrude the family type. Can someone help me with this.
I put the wetransfer link with the files https://we.tl/t-sTMJvtuIyi
Hi and welcome.
Do you have an adaptive family for the tunnel segments?
I made the family with an adaptive generic model, but I do not know if it’s correct (I’m a novice in this). I have attached the files in my first comment. Thank you
Translation by moderator team.
Original text below.
la familia la hice con modelo generico adaptativo, pero no se si está correcto (soy un novato en esto). he adjunte los archivos en mi primer comentario. gracias
You dont have Reference Points in the family.
Make sure to use 3 or more, and set them to be adaptive.
he realizado lo que usted me ha mandado y ahora tengo 4 puntos adaptativos. pero el resultado es el mismo, yo creo que me falta pero no se como hacerlo. adjunto archivo nuevo adaptativo
I will only answer questions in english, sorry
I just can not understand spannish (yet)
I have done what you have sent me and now I have 4 adaptive points. But, the result is the same. Attachment new adaptive file
https://we.tl/t-BMqK4KcOUl
Thank you very much Andrew. I’ll keep trying and upload the file with the new results. about Dynamo scrip is fine?. Or you think I should approach it differently?
Is that exactly what you want to do?
Adap.Comp.Tunnel.dyn (85.7 KB) Family2.rfa (428 KB) tous doc.rfa (800 KB)
Durmus
that looks good to me
if that is correct the result. what I’m going to look at the scpript, to be able to understand and ask you the doubts. because I would like to learn well. Thank you
Hey @Durmus_Cesur can you send me the family file in Revit 2019 version?
Hi @vinh.tran ,
Solutions have been produced and shared for this topic.
Please open up a new topic.
Durmus
Hi @Durmus_Cesur
it is possible to create a tunnel,
- make a point family from a 3D civil polyline
- make a 2d profile from a cad profile
- perform a type of extrusion with an xyz path
How is it done more specifically?
here I attach the elements
What is the best way to do it?
can you make an example please?
in revit 2019.2 please
As a matter of fact, dozens of topics have been opened and resolved in the forum. You can install RVT2020 and review all the files I share in detail and do the same.
But if you’re still going to insist on it, please share a new topic with us and wait for an answer.
Durmus.
Hi, it could be possible to send me the XL file format for reference? because the link is expired.
@Durmus_Cesur could you please share the XL file for my reference?
Please refrain from posting email addresses in the open forum. It leads to increased spam and bot farming, and in a half day time likely gets you on a few really annoying mailing lists.
